diciembre 12, 2019, 08:21:06
Autor Tema: #s de parte mazdaspeed  (Leído 4652 veces)
Desconectado Elmer-Homero
« : junio 26, 2011, 00:35:51 »
Pues buscando una pieza me encontre esto en el foro gringo de speeds, espero sea de utilidad
mazdaspeed accessories
mazdaspeed3 coilovers - RAMS8ML10
mazdaspeed3 springs with 2 rear camber links - GRMS8ML25
mazdaspeed3 rear camber links - GRMS8ML07
mazdaspeed3 cold air intake - GRMS8ML29 - who knows if they sell this?
mazdaspeed3 cai filter - GRMS8ML10
mazdaspeed3 exhaust - GRMS8ML26
maintenance
regular filter with o rings - L321143029U
spin on conversion - L31114311 and gasket - LF0114342
spin on filter - LF0514302A
drain plug washer - 995641400 - this normally comes with the filter
filter wrench - AKS75140
spark plugs - 000018L3Y3
drive belt - L3K915909A9U
radiator thermostat - L33615170
ignition coil - L3G218100A9U
exterior
front bumper mustache - BA6R50B31A - to remove the holes left from your front plate bracket
undertray aka lower shield - BP4K56111L
skid plate, radiator support, the piece that is on the bottom in the front of the vehicle - BP4K56112
mazdaspeed3 wheels - 9965097080
forged mazdaspeed wheels - BLMS8MZ01
center caps - G22C37190A
interior
coin holder - G22C55225
shift knob - GP9A46030B
under the hood
cylinder block - L3K910300H
valve cover - L3M610210A
mazdaspeed3 battery box tray - B37F56040D
mazdaspeed3 battery box and ecu cover - L33X18593B
mazdsapeed3 battery box front panel - L33X18591A
tmic cover - L3K9207B0F
oem egr tube - L3K920310A
oem egr valve - L3K920300
maf - L3K913215
map - L3K918211A
pcv - L3K913890
primary o2 - L33X188G1C
secondary o2 - L34B18861A
boost solenoid - L3K918741
ambient temp sensor - G51861764
knock sensor - L80718921
crankshaft position sensor - L3K918221A
mazdaspeed oil cap - BLMS8ML02
oem fuel pump - L3K91335ZC
oem boost tube from turbo to intercooler - L33L13760B
mazdaspeed3 (fits 2007 ms6) oem boost tube from intercooler to throttle body - L33X13770A
mazdaspeed3 oem cold pipe - L33X13241A
turbo oil drain/return line - L33E14290
gasket for top - L3K914293
gasket for bottom - L3K914264
bolts for previous two items - 9XF002127L
tensioner pulley - LF1715980E
brakes
mazdaspeed3 front brake pads - B3YF3323Z
mazdaspeed3 front rotor - B37F3325X
mazdaspeed3 rear brake pads - C2Y32648ZA
mazdaspeed3 rear rotor - C25Y26251B
suspension
mazdaspeed3 front sway bar - B37F34151
mazdaspeed3 front end links - B37F34170A
nuts for front end links - 999401001
mazdaspeed3 rear sway bar - B37F28151
mazdaspeed3 rear end links - B37F28170A
nuts for rear end links - 9YB101005
gaskets
head gasket - L3K910271C
turbo to manifold - L3K913710
turbo manifold to head - L3K913460
downpipe to turbo - L3F213490
intake manifold gasket to head - L3K913111
throttle body gasket - L3K913655
donut gasket - L3A140581
bpv to cold pipe oring diamond shaped "gasket" - L3K920255
fasteners
turbo and manifold studs - L33E13146A
nuts for studs - JE1040355
1st generation Black mica Mazdaspeed3
Desconectado batukOINK
  • Mazda Kabura
  • The new batuko´s car! the evil it´s back!
Re:#s de parte mazdaspeed
« Respuesta #1 : junio 27, 2011, 18:41:28 »
Good info porky
Good info!
Desconectado benx86
  • -Boyz Team Member-
« Respuesta #2 : junio 27, 2011, 22:07:14 »
son para speed 1ra generación vdd??
« Respuesta #3 : junio 27, 2011, 22:42:24 »
Si son de speed 1a gen pero algunas partes son compatibles como las pastillas de freno
Desconectado E82 PoLo
  • THE ULTIMATE DRIVING MACHINE
« Respuesta #4 : junio 28, 2011, 09:39:55 »
Valiosa info, Thanks!   8)
BMW 125i Coupe
Powered by BMW Motorsport
Desconectado daigoro
« Respuesta #5 : septiembre 21, 2016, 11:46:21 »
Buena Info saludos
